Tail lights upgrade
127 Views 4 Replies 3 Participants Last post by  Rsg
Hey folks, does the 2017 face-lift tail lights fit on the 2014 pre face-lift models or do I need to replace other parts?
You just need a conversion harness or to repin the connector for the lights to function correctly. Otherwise they bolt right in.
Cool. Because I do like the newe lights that's about the only think I want from the face-lift
Is there a conversion harness available?
you can buy the conversion harness from powerfuluk, alibaba or eBay. Readily available and pretty cheap. I went with original lights because I found a deal that was too good to be true, but there are aftermarket options that are available on the above three sites as well.
