Anyone use a tablet for running RRC-specific software - like RoverGauge or EAS Unlock suite?
I've got an old netbook that I'm about to toss and thought a tablet might be a better ease-of-use and battery option.
Discussion Starter #2
Just an update, I'm now running EAS Unlock and RoverGauge on a Win8 HP tablet.
How were you able to download make the .exe file to run the Rovergauge? I am stuck trying to figure out how to make the stuff on Github into something I can use...
Tulsa,
Sorry, I just read your post from May! IT was straightforward install, following the Github instructions posted here. Below is a cut-n-past of these instructions.
----------------------Installing and running----------------------If you're running Windows, the simplest way to get started is to download theWin32 binary archive. Most people will probably want to do this. The archivecontains the RoverGauge executable, Qt libraries, and libcomm14cux library,all of which are required to run. The files should simply all be placed in thesame directory with rovergauge.exe.
