Converting a T4 PC with RDS to start up as WXP .
(26-10-2007)
There is currently no automatic way of removing the T4Menu from start-up. Following the steps below allows the user to access the windows desktop from start-up and run applications (including the T4Menu) without the T4 main Menu.
Registry.
The following keys must be removed. It is recommended that an export is taken first.
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Current Version\Run\RDS Start
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Current Version\Run\RDS Compatibility
Change.
HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\Current Version\Winlogon\shell\T4Menu.exe to Explorer.exe
Files.
In c:\rds\rds.ini change shutdown=yes to shutdown=no.
Reboot the PC to complete changes.
Did this answer your question?, if not let me know `)
Brian.
(26-10-2007)
Registry.
Change.
Files.
Brian.
