Synthetic oil for high mileage engine
9413 Views 13 Replies 7 Participants Last post by  pontoon
What would be the best synthetic oil to use in a high mileage engine?
Should i continue to use the originally recommended mobil one fully synthetic or should i be switching to a special brand that would serve the engine better due to its high mileage?
I have currently clocked 245,000 miles (
394,289.2 km)8)
Many thanks in dvance to those who respond
1 - 14 of 14 Posts
394,289.2 km)8)
Impressive mileage! What year and engine L322 do you have?
at that mileage i think it wld be silly to alter anything, stick with what works
I'm at 350,000 kms. I'm using fully synthetic 10w40
I would just keep using the same Mobil 1 synthetic. As long as you're changing your oil regularly and keeping up with maintenance it really doesn't make a difference. I run regular full synthetic in my Range Rover and all my BMW's, even the ones with 200k+ miles.
Hi Doc , i have a 2005 full size vehicle ,4.4l bMW M62TU Engine , I love it.
When i got it it had been through 5 different owners and all of them gave up on it , the most annoying issue according to them was the terrible noise from the lower windshield seal so i bought it cash and fixed ll the minor gremlins and its been pretty good since then. At the time it had 80k miles (2012)
Great advise thx
Thx Danny , so you still use the 10w40? or are you using 5w40 or 0w40?
2005 L322, 200K and climbing. AMSOIL 0W-40 every 5-7K...I have used Mobil1 0W-40 a few times....
Very cool to see, thanks! I just switched from Mobil 1 Extended Performance 5w20 to AMSOIL Signature Series 5w20 in my 5.0 NA V8. My oil change interval is every 7,000 - 10,000 miles depending on type of driving.
I switched to AMSOIL mainly due to its lower volatility (NOACK < 7%); hoping it may help lower the carbon build-up a bit.
2005 L322, 200K and climbing. AMSOIL 0W-40 every 5-7K...I have used Mobil1 0W-40 a few times....[/QUOTE)
Why 0w40? is it much better than the 10w40 recommended from the get go? whats the key advantage in using this particuar oil? thx
Interesting , this is thefirst time i am seeing the use of 5w20 in these rigs , i will definitely research. Thx Doc!
Oil needs to be specced for the car and also the region you live in, ie how cold or hot it gets.
Viscosity is notated with the common "XW-XX." The number preceding the "W" rates the oil's flow at 0 degrees Fahrenheit (-17.8 degrees Celsius). The "W" stands for winter, not weight as many people think. The lower the number here, the less it thickens in the cold. So 5W-30 viscosity engine oil thickens less in the cold than a 10W-30, but more than a 0W-30. An engine in a colder climate, where motor oil tends to thicken because of lower temperatures, would benefit from 0W or 5W viscosity. A car in Death Valley would need a higher number to keep the oil from thinning out too much.
The second number after the "W" indicates the oil's viscosity measured at 212 degrees Fahrenheit (100 degrees Celsius). This number represents the oil's resistance to thinning at high temperatures. For example, 10W-30 oil will thin out at higher temperatures faster than 10W-40 will.
Thank you Envogue for taking the time to explain that clearly , i had no clue. it makes a lot of sense now and thus i can make an educated desicion on what 'weight" oil will est suit my travels and general location the vehicle spends time in. thank you very much .
Have a great weekend.
1 - 14 of 14 Posts
