Not sure if this is at all normal or even a concern, but here goes. 2013 Sport HSE with ~8k miles.
Occasionally, after parking and turning the ignition off, it seems that the rear suspension drops ~1-2 inches. I hear a slight "hiss", and within 5 seconds of turning the truck off, the rear of the truck seems to settle. There's still 4-5 inches of travel between the rear tires and the wheel well. Seems to happen more when there's a heavier load in the car (e.g. kids in the back seat). Suspension setting are all normal, normal drive mode, etc. Just regular street driving. The "drop" probably happened 2-3 times in the past 10-15 or so trips.
Other than that, its been tip top.
Any thoughts?
When you have weight in the back the rear air struts inflate to level truck out. When the kids get out the truck then airs down to level again when weight is removed. Completely normal.
