Hi, can anyone shed some light on a suspension issue on my RRS SC 2006, when I drive over a speed bump or even a dipped curb the front right suspension has a bit of a fit, it continues bobbing up and down vigorously for a second or two after, with a knocking noise. This doesn’t happen every time and only seems to happen at slower speeds??
Start with inspecting the sway bar bushings then the lower control arm bushings & ball joint for play. I confirmed simmilar issues by mounting my go pro under the frame focused on the lower control arm. I clearly saw abnormal play in the LCA bushings. If it is just bouncing check the strut while parked to see if it is dampening as it should. How many miles on the truck?
Hi, thank you for your thoughts, truck has around 130k miles, this fault has occurred in the last few months. Regards
