Hi All
I'm wondering if anyone could shed any light on a problem i have, it started on Monday everything was well driving home from work until i stopped at the shop then when i started up the car i got several different fault codes, park brake fault, transmission fault, HDC fault, rear wheel speed sensor fault and suspension lowering, i got the car home and replaced the battery as after a cca test it showed battery health at 52%, this resolved a lot of the fault codes and as i had read so much about the brake switch causing problems i replaced that as well,
All the faults have appeared to have gone but I'm getting a message on the dash that "suspension will raise when system has cooled" but the car had been left for 24 hours and the compressor is not coming on, i have plugged my iiD Tool in but there is no DTC's for the suspension system.
any help would be much appreciated
Many Thanks Dave
did you ever solve this?
