Hi, RR L322 2006 TD6 suspension raise /lower seems to have failed. When I go to lower I get suspension fault on the dash & try to raise it says start car to raise ? any idea's .......
RIP Our Friend
If your front struts/bags are original then they have most likely been leaking and your compressor is worn out. However, you really do need to pull the error codes to see why the EAS is in safe mode.
You need to follow the advice provided but as you have a a RR L322 (a Full FAT RR) you do need to go to the right forum. Also while the second series of the L322 has the same basic air system of the D3/L320 your early L322 system is closer to the old P38 air system.
Garry
