My 2006 RR HSE is throwing a "Suspension Fault" error and also a "Suspension Fault Normal Height Only" message.
I found the Hitachi compressor and replaced it. It appears I may have thrown some money away because the problem persists.
When I start the car the compressor will run for about 2 seconds then it stops and it throws the "Suspension Fault". This is highly repeatable. I can hear no hissing anywhere in the system. If I remove the line that goes from the Valve block to the desiccant chamber there is pressure building up in there. Interestingly enough though, if i run the system with that line disconnected the pressure comes from the Valve block - which confuses me a bit.
I wonder if anyone has seen anything similar and perhaps could give me some pointers - I'm considering throwing away more money on a new valve block - but i have a strong suspicion i am barking up the wrong tree.
Thanks for any advice.
