My 2010 and 2011 pretty simple - replace front struts and rebuild the compressors. No issues since. If your front struts are over 10 years old, renew them.
Check the date codes on the strut.
Particles of grit build up in the compressor piston. Grit and dust also block the filter/dryer inlet. The compressor needs to come apart to be cleaned. Same for the filter/dryer (or order new) So between those two issues you get reduced compressor performance and high comp temperatures.
