Hello....
I have Range Rover Sport 2006 and i recently test the hydraulic switch when selecting high mode its raise normal , then I press normal height its returned back to normal height back normal too , but when I select the low mode with lock position its lowered and suspension locked at access height appears then returned to normal height (automatically) with suspension in extended mode appears . Can anyone help please ??
What is happening is when the suspension has gone down the car thinks it has grounded so automatically it goes back up to extended mode.
I believe this normally happens when a height sensor is either out of adjustment or faulty - you need to recalibrate the suspension and this should fix the issue. I am not sure how you do this so you will need advice from someone who knows this.
Garry
Thank you very much sir , i will check that I hope that will be helpful 😊
