1 - 9 of 9 Posts
My front suspension has recently been dropping intermittently. Sometimes when it does drop it won't raise for hours or days. Then it can stay up for days at a time. I've had it in a rr garage who after 2 days have said the air compressor is overheating and therefore opens a valve and let's the air out and as such need a new compressor at a cost of approx £1000. Anyone know if this is all correct?
Many thanks
get the kit to replace the O ring inside the compressor with all Seals. I did mine. the kit cost £12, and now it works with unbelievable pressure.
It's half that price if you do it yourself
If anyone had find a better price please comment and quote me.
I do not sponser this business. I just did a search. Sorry for the advertisement
Sent from my Pixel 3 using Tapatalk
Next time you know you're not using the vehicle for a couple of days, with the vehicle at standard height, measure the height of the front bumper (from the ground) and then disconnect the battery for 36-48 hours.
If the front of the vehicle "drops" over that period, the problem is most likely to be one or both leaking front air suspension bladders. If it remains at the same height, the problem is more likely the valve or compressor (ie not a leaking airbag) or an electrical issue.
At least that'll set you headed in the right remedial repair direction.
Please report back on your finding(s).
Rob
I've just bought repair kit will get onto it Saturday. Cheers
Rob
I'm going to repair compressor then try your advice at weekend. I will post any results.
Update. Have reconditioned compressor and still no change. Front will not pump up at all. I can hear pump running but no air is going i to the front. Although no air is released or inserted into rear. Am going to bite the bullet and order a new compressor and see what happens from there
Did you refresh the compressor assembly's drier filter too?
There's silica desiccant within the filter, to absorb moisture, and if that has crystallized your compressor's output may essential be blocked with solidified drier material.
Does the compressor produce pressure with the compressor hose to the distribution valve at the rear of the compressor assembly disconnected?
Rob
After several searches and a new compressor it turns out i did indeed have a knackered compressor that for some reason allows air to escape from front drivers side, as I have tried refitting it after testing new compressor. However i also had a pin hole in the air suspension tank. New compressor on and new tank fitted, so far so good. Will play around with over next few days see if codes or issues pop up.
1 - 9 of 9 Posts
