Hi guys,
I've been having starting issues with my p38..
When it's left overnight it turns over for a while before it starts, I've replaced the sender unit & pump, also put a none return valve just before the filter, replaced the leak off pipes..
However, I've just pulled the leak off pipe on injector 1 (while running) to make sure that the fuel is pumping through correctly and managed to get a small pool of diesel in the recess where injector 1 is.. I then noticed that there was air bubbles coming from the pool of diesel..
I then got a screw driver to slightly pry the injector to see if it got better or worse & it got worse.
Have a look at this video (if you can see it): https://instagram.com/p/BT9p24Bj3eg/
Can someone please help me with this?
Am I right in thinking that the injector seating seals are gone?
Can someone help me locate the replacment parts & a guide?
Could this cause the starting issue?
Sorry to bombard with loads of questions & many thanks in advance
Ash
I looked at replacing the copper washers under the injectors and I couldn't source any.
I would get the proper injector socket (with the cut out) and tighten them to the correct torque setting as per RAVE.
JACK'S GRANDAD
As well as putting all the rigs information in your sig line, if not in each and every thread.
