help... anybody know where can i find the fuse for the vanity mirror.
I replace the bulb and two of my sunvisor missor, two dome light and passenger light switch stop working.
Center dome light still working and truck.
did you use an LED bulb? sometimes LED bulbs are rejected by the others and cause issues. otherwise the manual should list all fuses. what year is your sport?
2010-2012 Range Rover Sport
I recently installed LED lights and all of them worked except for the driver side door security ground light. I’ve tried a few bulbs and it looks like it completely dead (fuse blown?) but all of my other lights have taken to the LEDs. Are the lights individually fused or did I burn out the wire/circuit between the fuse and LED?
Some LED bulbs will only work one direction. Remove the bulb and flip it around. If it still doesn't work it could be a duff bulb. Have you tried it in the passenger door puddle light fixture? Have checked the socket for power?
it was a blown fuse located by the GLOVE box. I end up putting the factory bulb back on the sunvisor now passenger sunvisor light is not working. Still trying to figure this out.
