Hey, I recently purchased my 1999 4.6 HSE P38 and the sunroof was working fine for the first couple days. Last night I tilted the sunroof and now it's not working anymore. Every time I attempt to close it or even open it all the way it reads the "sunroof not set" error. I read the FAQ about this error but I am unable to perform the actions to "set" the sunroof because it is stuck in the tilt position. Any advice?
Thanks,
Mike
Awesome, I'all do that first thing in the morning. Any other possibilities?
JACK'S GRANDAD
Check that, then worry about other possibilities......Of which there are really none.
Martin
Have the same now and then. I removed the courtesylight and turned it by hand while pressing the button and electrics picked up again. I have to look it over but at least it is closed.
My runners broke down but I bought a replace from junkyard for 200 dollars and replaced whole sunroof. Take out the glass and it is a one person job . Cover dash with thick towel, Lube your new one good be cause that is likely the reason for failure. Good luck
