Hi guys I need some help. I opened the sunroof and it just stopped dead about half way. It made a mechanical noise and stopped. I hit the switch and there was no noise coming from the motor. I took the headliner down and I was able to put an Allen wrench in the slot and hand crank the window closed or close to. I replaced the motor & switch new from Land Rover. The new parts are in and I still have nothing. There is no noise ok’ing from the motor so I checked the fuse and the fuse wasn’t blown. Is there a reset procedure I need to do?
There is a reset procedure. Push and hold the sunroof close button. Keep it pressed and after about 25 seconds, the sunroof should open and then close. Once it has completed the cycle and has stopped in the closed position, release the button. This is the procedure that resets/ re calibrates the sunroof. I hope it works for you.
