Hey guys my sunroof is not opening anymore. Can any one help trouble shoot this for a home fix or is this something I need a mechanic to take care of?
Thank you.
Thank you.
Apologies, but you simply haven't provided enough info fo us to be able to help you out. :think: What does it and what does it not do? Are you talking vent position or slide position? What have you done so far?medcapequip said:Hey guys my sunroof is not opening anymore. Can any one help trouble shoot this for a home fix or is this something I need a mechanic to take care of?
Thank you.
The best thing you could do for your switch pack is to clean it. The wonderful placement of the switch pack downstream from sodas and coffees puts it in a unique position to gum up and or short things out. The board is easily removed from the switch pack. A few sprays with MAF cleaner has done wonders on more than a few that I have saved from the scrap bin.BargePilot said:Mine doesn't even give a hint in the binnacle display. I long suspected the switch pack. I hoped there would be a troubleshoot procedure in the ETM but I didn't see it. I wonder for instance if it's possible to directly put voltage on the motor, thereby ruling out any problems in the wiring or the switch pack.
On mine the switchpack is the primary suspect. Anybody know why /how switchpack breaks? There simply aren't enough wires from the switch pack to the BeCM for each switch to operate directly. It must have some logic to translate switch settings in a (serial? heaxdecimal?) protocol to communicate to the BeCM. Since every other thing on my switch pack continues to operate flawlessly, the logic can't be broken, it can only be a problem with the central sun roof switch. I took it apart as far as I could get it apart, but couldn't fix it / find a problem with that switch.
Maybe I should try again. Sorry to hijack the thread, back to medcapequip.
