Bought a 97 4.6HSE a few months ago and with the help of this forum replaced the fan clutch, got seats warm again, got the cruise control cruising, the windshield washer squirting and the radiator bleed leak stopped with some JB Weld. My turn to contribute. I successfully fixed the drivers window switch by removing the panel and taking out the circuit board. I removed the switch cover and then the rocker portion of the switch from the board (don't lose the spring!). I peeled back the platic membrane from beneath the switch with a sharp blade and then squirted contact cleaner under the membrane. I worked the bubble switches up and down for a minute with a stick then plugged in the board. Switch worked great! Reassembled it and it's been working fine for 3 months. The breakthrough was with the peeling back of the membrane as I had previously tried squirting contact cleaner under the switch with no success. Saved me a couple of bucks for a new board anyway.
Joe
97 4.6 spring conversion
140k with 45k on factory new engine
2006 l322 Westminster #41
Hi and welcome to the site. Have not been there yet but will file away that bit of info. If you are computer literate this board loves good pictures. Someday I'll get it. Cheers.
Hi, I'm hoping someone else has tried this... I was trying to clean one of my window switches and accidentally broke 1/2 of the rocker piece under the switch cover. Is there anything I can do to fix this? Maybe add some small plastic material under there? Or am I stuck buying a new switch pack? Below is a Hi-Res image of the piece I broke.
Hi to all Re repairing plastic parts I always use a Mitre Mate adhesive system this is a two part system using a spray activator this is sprayed on to one part and left to dry then on the other part you use a cyanoacrylate adhesive then bring the two parts together this system as never let me down no mater the plastic you are repairing. this is the adhesive used by double glazing contractors. good luck sillyboy
