2010-2012 Range Rover Sport
2016 RRS SC
The Subwoofer sounds like crap in my car.
Is there an aftermarket replacement or stock Harmon Kardon only?
Thanks.
Brian
Of course there is a replacement. Pull your current sub out and get the specs. You can visit the local car toys or order from Crutchfield.
Yes I agree. I don't know why Harman Kardon are apparently so highly thought of, Any car I've ever had with an HK system has always sounded like cheap crap to me. The stock Bowers and Wilkins speakers in my Jag sound waaay better.
My Sub works great - are you sure it is not the mount that is making it sound so poor. The sub can come loose and vibrate as can anything else near where the sub is mounted like the panel trim.
The reason I asked is in my Lexus wit the Mark Levinison sound system it uses an odd ohm rating and it is hard t match aftermarket speakers.
The sound is muddy, poorly reproduced not a vibration issue.
you still need to try Crutchfield. For a Lexus or for a Sport, pull the old one out and get the specs off the speaker... it really is that easy.
