1 - 10 of 10 Posts
So went to go to an interview this afternoon, went outside turned it on and let it warm up for about 15-20 min while I got ready. Went back outside to leave and noticed the oil gauge was on red. quickly turned it off and went to turn it on again thinking it was just a weird glitch ( my gauges decided when they want to work so didnt think much about it ) now it wont turn over... the engine goes knee knee knee knee cough sputter knee knee knee..... what could this be?! There is no liquids leaking out that I can see..... Oil level is fine just checked it again.
Sounds like a battery issue. Our canadian tire battery lasted just shy of 3 years and failed quickly while testing the fuel pump with ign. off for a few minutes (but not running) It had just started before that time but i noticed that the idle speed was up soon after a decent run which usually was low. would be a good idea to get the battery load tested and/or check the charging circuit which may have prevented the battery from charging
If the engine is turning over, which it sounds like it is, it's not likely a battery issue.
I don't know if if the 02-05 have an oil temp gauge, but the 06+ don't.
You sure it wasn't your coolant temp gauge in the red?
Did you check your coolant level? Anything temp related I would check coolant first thing...
2006 L322 4.2L SC
JACK'S GRANDAD
If the oil switch is bad, most rigs will not run. They do it to save the motor.
Martin
2006 L322 4.2L SC
So I checked my Coolant Rez and it was bone dry! but now im just confused as to why? I just replaced it because the other one cracked. There is no puddles or drop marks under the truck....where could it all be going so fast??
Was it your *oil temp* guage, or coolant temp gauge that hit red?
2006 L322 4.2L SC
Considering my 05' doesn't have an oil temp gauge, we can all assume it was the temperature gauge.
I wasn't sure if 02-05 had an oil temp gauge lol. I have an 06
2006 L322 4.2L SC
Didn't mean to come across rude :lol:
The 06-09 instrument cluster is about the same as the 03-05 just a bit different in terms of styling and colours, the bottom displays were changed from 4 different to 2 different screens.
Discussion Starter #10
sorry yea you're right im an idiot hahaha
1 - 10 of 10 Posts
