Lord Nelson has pulled a temper tantrum and refuses to start. Battery is new (Optima).
Last time it did so I clean the ground cable contact at coil and it started.
This time I went all the way replaced coil, checked dizzy electronic plate ( ohms ok), replaced ignition amp anyway
replaced also condenser on the + side.
Checked fuel pump and replaced it with new unit. Tested new unit using spare battery to pressurize system. Hooked up
pump and replaced pump relay under seat.
However no sparks from new coil.
Decided to verify all electric connections per service manual.
Main relay (2) (red stripe one and new Taiwan) appear to be dead (will not click).
However, relay base has power in both sockets (30 and 86) with ignition off. I should get power only with ignition on in 86.
ECU plug after voltage test (19) has no power with ignition on.
Appear to have a short somewhere or I must have missed something.
Any suggestions ?
Cap and rotor were not replaced since they are new.
Issue lays with the main relay. It appears that the Taiwan version of the bosch unit is bad. It will not click under power applied to terminals 85, 86.
Will try yo get one at the local NAPA.
never assume the distributor rotor is good, plenty of dead on arrival units
