Went to shift. Stuck in reverse. Can't get key out and it won't crank because it's in gear. The resistance in the chrome par of the shifter you use to engage the gears is gone. Any thoughts?
on the back side of the shift "knob" is a small phillips screw. Remove the screw and pull straight up on the knob to remove. you will see a white nylon rod in the center of the shifter shaft. Depress this to shift. If it does not depress or will no shift then you will most likely have to pull the ashtray trim assembly and shift plate out to find the issue.
Bingo! Thanks! I suppose I need another shift lever, where to find one?
eBay or one of our member vendors listed in green.
