1 - 1 of 1 Posts
Hi
On my 02 TD6 the FBH does not start when my motor is running.
Parking heat however can be selected and works both on the screen as on the remote.
If I start driving -15 degrees outside very cold motor and interior it should com on automaticly.
We'll it does not
I can't even select the aux heating
After the motor has warmed up ( lucky there are some steep hills) and it reaches it's normal temperature if it then cools down I suddenly can select aux heat but it is not working. The led is flashing when selected.
Help please ( it gets really very cold coming down the mountan without the FBH)
1 - 1 of 1 Posts
