My RR had the self-leveling bi-xenons 2004 RR, I did the upgrade to the 2006/09 front end using NON-AFS bi xenon headlights.
I used the connectors from Powerful UK - wired just like the diagram, everything works with exception of the tiny side marker lights.
However, when I have the headlights on I get two errors, sometimes 20 min after they are turned on, sometimes 5min after they are on.
I get a check highbeam error, or I get the check fog light error. When I turn on the high beams and fog lights for about 1 min the error codes go away.
please help :(
Discussion Starter #2
Does anyone have any ideas about this? Perhaps fitting a resistor inline with the high beam, low beam, and fog light positive leads would solve it???
