I am trying to bypass the rear amplifier in my 1991 classic - does anyone know where I could obtain a plug/harness so I don't need to cut out the original plug and hardwire? It's an 11 pin plug and I would need the male side (amplifier) Any input much appreciated.
W124 chassis Mercedes share similar connectors to accommodate the Becker BE1492/BE1692 head units - you may find wiring options there too? Unfortunately, I do not have any photos.
Thanks for the tip - I did a little searching and while the connectors share the same type of pins, the pin configuration seems to be different with the two rows of pins directly over one another and usually 8 / 12 pins - the two rows of pins in the RRC plug are offset... I'll keep looking though. Cheers!
