I took my steering shaft out to have it lengthened for the RTE two inch body lift. Everything went fine and the shaft is ready to go back in. However, the U-joints look pretty nasty and I would like to clean them up before reinstalling the shaft. My questions is how should I clean them up and what should I re-grease them with. My current thoughts are clean them with some mineral spirits and a toothbrush and then re-grease with some bearing grease. Open to any suggestions as I'd like to do it right the first time.
Clayton
Hiya Clayton,
Clean up sounds about right to me... at least that's what I do !
The RAVE manual indicates NLGI - 2 Multi-purpose Lithium based GREASE for - Propeller shaft Front and Rear,
Lubrication nipples (hubs, ball joints etc.), Seat slides & Door lock striker.......
That's what I'd use.... unless someone else can chime in with another opinion. :thumb:
Rod
Banned
You do not need to extend the steering shaft for a 2 inch body lift, a standard shaft fits fine.
There is no real way to grease the steering shaft unis as there are plastic seals on each area. I just spray some WD40 on them from time to time and it seems to help.
