I need to replace mine.
Does anyone know why the first is about twice the price of the second?
or
Thanks - Tom
They both appear to be the same part - a P38 steering shaft, unless I missed something obvious. I'll probably go with the more expensive one anyway.
Super Moderator
I bought a Europarts one about 3 years ago and, unlike the original, it is all steel rather than alloy with a hex shaped centre section rather than fine splines. Never got around to fitting it (adjusted the steering box and found I didn't really need it) until recently (something to do during lockdown) only to find a small amount of play in the bottom UJ. The one I got looked like the picture of the Britpart one with the exposed rubber joint at the top, whereas the picture of the new Europarts one looks slightly different. I ordered an OE one from LRDirect (QME500190 | Steering Shaft - Land Rover Part QME500190) expecting it to be the alloy one but again is the all steel one but this time without the play.
LR Direct's OE part appears to be the Britpart too with the same part number as Island 4x4:
Land Rover Steering Shaft|Part Number:QME500190|Brand:ORIGINAL EQUIPMENT|Supplier:BRITPART
The Eurospares part appears to be the lower cost option, but my mechanic here regularly fits them without issues and I can get one locally for not too much more than on line so I'm going that way. Mine has lots of play in the rubber coupling.
Thanks Richard
Just got my Eurospares shaft delivered. Looks very nicely made with no play in any of the three joints. New one goes in with Torx bolts whereas original has bolts.
