1 - 1 of 1 Posts
I've had problems with my electric steering adjustment since I bought the truck. From day one, the steering column hasn't works and has been permenantly jammed in the highest/furtherest position. I checked the fuses and they're ok and bought a new lever and that wasn't it either. I managed to get the tilt function working by loosening the nut on the tilt mechanism and it works perfectly on the lever
My issues is the telescopic function. It works when I plug it into autocom and adjust using the laptop software and it also works on the seat memory buttons. I can't get it working on the lever or the replacement lever I bought.
1) fuses are fine
2) motor works
3) can be operated via laptop
4) can be operated via seat memory buttons
5) doesn't work on adjusting lever (or the replacement I bought)
Thoughts????
1 - 1 of 1 Posts
