2004 Range Rover, 130,000. I have been working the last few months on timing chain guides. Timing chain cases are back on, tensioner installed, valve covers on and oil back in the crank case. I turned it manually to make sure I wasn't way off on the timing. Then I cranked it with the starter. So far, So good.
I would like to do a test start before proceeding. I was going to install the coils, cam sensors and vanos. Does anything else need to be installed to allow the truck to start? Since I have no coolant, I am only planning to run the truck for a min or less. I just want to be sure I don't have timing issues before proceeding.
