I've got an 06 2.7tdv6 l3 .its been stood awhile and I'm trying to get it started again .have charged battery fully .put fresh fuel in tried to start turns over but no start.have turned ignition on and tried bleed valve on engine the tyre valve one.it squirted a little bit of air then a small bit of fuel came out .should fuel continuosly come out when pressed.if so do I have a pump problem.
