Hi there I am hoping somebody knows where the starter motor relay is in my 2006 L322 Jag. V8... it is not behind the battery where all the workbooks show it...?!
The car will not crank... changed the starter, battery is fine, I have no electricity to the secondary wire to the starter...
any help would be much appreciated!
Vehicle Automotive wheel system Wheel Automotive tire Geological phenomenon
2010 SC 5.0 Range Rover MkIII / L322
did you try to start it in neutral? move the shifter around
IIRC the starter relay is in the big box under the hood
I tried... no luck..
Is it in the box behind the battery(i have nothing there besides relay for wipers)
Or in the main one(which one relay?)
Appreciate it !
Hi John, I have the same problem ... mine (if I have one) is not where the book tells me it should be (behind the battery). Like you if it is in the big box which one is it, it's not titled! :mad: Did you manage to find it?
Hi,
Quick question - how did you get the starter out? Seems you have to remove the exhaust manifold but I maybe. I have a 2006 4.4 Jag engine and I can't seem to get access to the top bolt of the starter after hours of trying.
Any help would be appreciated.
Paul
