Re: SRS Light / "Airbag Fault" Message - Possibly Legit
Check the wiring/connectors at the Front Crash Sensors if you've come down a bit hard on the front it may have damaged the wiring or dislodged a connector or something like that. Also as it's logged a fault you will need someone with T4 or Rovacom to check and clear it.
Just a thought.
Just a thought.
