I have read about the three Heater blender motors, the question I have is the motors are moving air from the floor to vents to defroster but no heat. The fact that the motors are moving the air but no heat, could the issue be other than the blender motors?
Thanks for your input.
Robert
Most likely your heater core is plugged. Lots of posts if you search the board. The most common complaint is no heat on the driver's side but still heat on the passenger side.
In my experience the most common cause of sudden no heat is a coolant leak, and low coolant level. The next most common issue, as Arby posted, is a plugged heater core. Check your coolant level first
