Hello,
I have an issue with my 1997 P38 Rover that I'm trying to diagnose. I have followed the problems/causes section of the website and have narrowed the issue down to a possible valve block leak or air line from valve block to air reservoir leak, but I'm hoping to narrow it down even further with the help of this board's combined expertise.
On some mornings, the car simply takes 20 minutes or so to raise, so I'll have to pull over during my commute or just reset the EAS fault with my laptop when I get to work. I've gotten used to this arrangement. I recently replaced the air compressor with a much newer one from a UK seller, and that drastically reduced the bumpy ride in the morning. However, the last couple mornings I came out to my car to see it still completely raised, and upon starting it the light is solid on standard ride hight - I thought my troubles were over. :naughty:
The EAS Fault still occurred at the 15-20 minute mark of my commute, though the light indicated the suspension was raised - which led me to believe the air tank just wasn't filling fast enough and that is causing an EAS fault (its the 35MPH max one). So my question is: should I look for my problem in the air line or the valve block, or elsewhere?
All help is appreciated.
Nick
Nick
