Hey everybody,
I have searched and found similar problems but not regarding my issue. My front speakers do not work. I tested my front speakers in the rear and they work fine so they are not the culprit. I am trying to trace the wires and check the connections and such but can only follow them back so far. Basically where do the yellow and white and yellow and green wires for the speakers in the front end up. I know the speakers work as I said so it has to be a connection in the wiring harness somewhere but where is my question. The previous owner installed a new head unit, amp and sub and everything but those front speakers is working fine. Behind the new head unit he installed a speaker level converter pictured below but as you can see none of the wires in or out are the same as the wires that hook up to the actual speakers. Any guidance would be greatly appreciated.
Josh
