I’m budgeting for a lift and tires on my P38 and I am wondering if I’m going to need a spare tire carrier for the hitch.
My question is what is the largest tire anyone has fit into the spare well inflated or deflated? The size I’m considering is 265/75R16, I don’t mind removing all of the foam if needed.
Thank you for the input.
Dr,
255 60 Toyo winter tire inflated will not fit, foam or not, without some heavy persuasion of metal. Don’t know about uninflated though.
Super Moderator
There was a discussion on this a while back, anything larger than standard will not fit.
Banned
Nope, have the exact same tire size & it isn't even close. Biggest I've seen fit are 245/45 with pretty aggressive tread on 18"s. Those are about 28.5" tall. The 265/75 on 16"s are a bit over 31". That being said, there is a LOT of room underneath, so if you don't mind a LOT of fabrication, and if you aren't running dual exhaust, you could have a larger tire well fabricated. I've considered it vs going with the aftermarket bumper option with swing-out. If I end up converting mine into an Overland rig, I might go both routes...as having a lot of cargo room for about $500-600 in fab expense isn't a bad spend IMHO.
I have 255/70s at 29 inches overall. I am wondering if I deflate the tyre will I be able to fit in a spare. I am about to head off on a big trip so will need to either do that or tie an extra spare to my camper trailer!
Anyone tried deflated fitting ?
I just put 255/70 R16's on my rig and can confirm it will not fit in the well either inflated or deflated. Fortunately I have a spare tire mount on my roof rack, but that makes my rig too tall to fit in the garage. /:( Now just to convince the boss I need a swing out bumper mount.:mrgreen:
Banned
Deflating a car/truck tire isn't like deflating a bicycle tire. You may get a bit of space, but the sidewalls on 99% of car/truck tires aren't exactly malleable except under substantial load.
