I noticed a chuffing noise after I filled the system back up with coolant. It seems like there is still air in the system but I don't know how to get it out. Any help is greatly appreciated. Thank you so much everyone! If you want a detailed overview of what exactly happened, read the essay below lol.
I've gotten the new pump on the truck, flushed the old coolant out. Ran an additive through the radiator and pressure washed the crap out of the condenser with the bumper off and the detached radiator. Filled her with coolant yesterday by filling the reservoir up, the block up through the return hose coming off the top of the engine, and radiator using a hose. Did this to minimize the amount of air that would be in the system initially. Started her up and the coolant in the reservoir went down. I topped it up and then started checking for heat on the hoses. Noticed the heater core wasn't getting hot. Stopped the engine and started blowing in the reservoir with the relief tube plugged and pushed the air out of the heater core. It seemed to work because I now get hot air. The system pressurizes fine, I get heat, and its not overheating. However, I am getting this "chuffing" noise that is only present when the engine reaches operating temperature. Not sure exactly where its coming from, but it sounds like its coming from the lower rear section of the engine. I let it sit over night and noticed the coolant in the reservoir went down considerably. I topped it up and started the engine. Took the truck for a 5 mile drive at 40mph with the a/c on. Temps stayed normal and everything seemed fine. Got back and noticed the chuffing noise again. I let it cool for a bit and then slowly released the pressure at the reservoir and heard some bubbling noises coming from some where (not sure where). I squeezed the radiator hose at the top and it really didn't feel like there was any coolant there... I don't really know what to do and hope you all can help. Sorry for the essay of a post, and thanks in advance!
