I drove with a broken one on the rear for 100 miles - take it easy around the corners - you will get more body lean - but if you just want to drive a couple of miles to the shop - should be no problem. The part is cheap - use lemforder
Or rangerover original - not cheap Chinese version. Might consider to replace sway bar bushings while you do this.
