Hello:
I was wondering if anyone may have an idea of what could be wrong with my 1996 RR SE. Any help or ideas would be very much appreciated.
Car has 70K on it when:
- the rmps would drop to the point that the oil light came on when at a red light
- car would lose all power when driving sometimes and the only way to get past it was to floor it or wait it out. It was always followed by a pop (maybe with a clunk - if that makes sense) which felt as if it was coming from under the driver seat.
- Mechanic has done the following:
a. misfiring shows up on diagnostics so *spark plugs changed, *ignition coil changed
b. cant get a MAF sensor anymore so he swapped it out with someone else's temporarily to see if that would solve the problem - it did not (it was temporarily better for about a day after he cleaned the one on my vehicle)
c. checked pressure all around and no issues there. The fuel pump was 33 or 35 (but normal is 34 right?)
d. ignition wiring replaced
e. O2 sensors all fine
f. transmission fluid fine
There are a couple of other things that I cant recall right now (as far as what he has checked out). This is the problem still - the car wont drive past 15-20 mph without misfiring and loss of power. He is the only mechanic I trust aside from a dealership (which is ridiculously expensive) and we cannot resolve this problem. Does anyone have any suggestions or experience with a problem like this?
Thanks.
- SpecialKNYC
Thanks.
- SpecialKNYC
