Smell of natural gas...not lpg!
1877 Views 7 Replies 6 Participants Last post by  TehPriest
hey guys, i have a 2000 2.5dtse p38. last night after a 20 min journey pulled into a car park, put it in reverse and got the smell of natural gas!!! i don't have lpg conversion or anything. when driving the smell isn't there, just took it out now, was fine when driving but when i got home just put it in Park and got the smell again... what the hell is this??? i have a small oil leak, could this be part of it??? help please...
Maybe something died in your vehicle? :think:
jimi hendrix?
Marc Bolan would be more appropriate.
He did say "natural" gas. Maybe he ran over a vegetarian?
ROFL!!! :lol:
I would check for fluid leaks first. Where is the smell coming from?
oil leak is coming from high pressure gearbox hose! seems that the smell is only there when i change gear lever, it's an automatic, could it be my clutch that the smell is coming from? big job? or (hopefully!!!) that the level is just down in the gearbox and needs topping up...
There is no clutch on an automatic. Or more correctly there are between seven and nine of them. But they are not user servicable items usually. Everything is controlled by the ATF oil and valves. If the oil gets too low then the clutches could start to burn (they are made of a special type of paper like material) and that may cause a smell. Not sure about natural gas though. To be pedantic LPG and Natural gas are both odourless. They add a stenching agent to make them smell for safey sake. I think they use the same agent and so the same smell ???
:pray:
