1 - 9 of 9 Posts
SUPER MODERATOR
Re: Another tech question!!
What doesn't give is you with rig information, a header that makes sense to anyone browsing or a hint of what you have already searched and read up on. :evil:
Use another battery, new from the package.
A known good battery is not good enough. The message is triggered at 2.44v in the key battery, and is not removed until the truck sees above 2.95v in the key battery, and considering that a 2032 battery is rated at 3v to begin with, one that has been used in something else, or has been in a drawer somewhere is not good enough to get rid of the message.
This is assuming it is a 10-11my truck, if it is a '12, go to the dealership, they will replace your key (if they're up to date on their SSMs)
Opps sorry for my vague discription..
2010 RRS Supercharged
Thanks very much.. my truck is still under warranty.. if the key is no good.. is that covered under warranty?? Thanks again for your help!!
You said it is a '10. Them replacing the key applies to the '12.
The key would be covered under the warranty, and the battery for it would as well, so if you are near a dealership, stop by, and they should be able to put a good battery in your key and have everything working correctly.
Special Service Message was recently issued to dealers about this, as RG7 says try again with a brand new battery out of a package.
Reference
SSM56277
Models Range Rover Sport / L320
Range Rover Evoque / L538
LR4 / L319
Range Rover / L322
Title 10my `Smart key battery low` message displayed in instrument pack message center
CategoryElectrical
Last modified05-Apr-2012 00:00:00
Symptom204000 Instrumentation
ContentVehicles affected, 10my Range Rover, Range Rover Sport, Discovery4/LR4
Issue
When the " Smart key battery low" message is displayed in the instrument pack message center dealers are complaining that after a replacement battery has been fitted the message does not disappear. The dealer then replaces the key in the belief that the key is faulty.
Cause
Dealers are swapping batteries from known good smart keys to diagnose battery low message or fitting aged batteries off the shelf. The message is displayed when the smart key voltage threshold has dropped below 2.44 volts. The message will clear if the smart key battery threshold is higher than 2.95 volts.
Note: these voltages are only measurable when the battery is inserted in the smart key.
Action
When the " Smart key battery low" message is displayed in the instrument pack message center dealer technicians and customers must fit a NEW still in the packet battery.
Under no circumstances should you swap batteries from a known "good" smart key.
LR part number is YWK10003L. (battery type CR2032)
Please note: CR2032 batteries stored in high humidity +75% & at high ambient temperatures greater then (+25degC) will greatly reduce its shelf life.
After replacement of the battery two smart key authentications need to take place to clear the message and to recognize the new battery voltage.
This is achieved by pressing any button on the smart key twice.
If the "Smart key battery low" message does not clear in the message center fit another new battery and retry.
If the "Smart key battery low" message is still present please replace the smart key, submit an EPQR and retain the smart key and all associated batteries for investigation. Please label the original battery and replaced battery separately.
And RG7 is also correct about the 2012s, problem is "under analysis" currently:
Reference SSM60957
LR4 / L319
Title 12MY Smart Key Battery Low Message
CategoryElectrical
Last modified22-Nov-2012 00:00:00
Symptom205000 Electrical Accessories
ContentIssue: A customer may report a concern that the message ‘Smart Key Battery Low’ is displayed on the Instrument pack when the key handset remote is operated.
Cause: Currently under analysis.
Action: Replace the key handset and battery and submit an ePQR, where the customer has reported the concern within the first 12months of service on the following 12MY onwards vehicles only:
Discovery 4/LR4, Range Rover Sport, Range Rover Evoque
Note: It is important that the battery is not disturbed/ removed from the faulty key handset. The original handset should be returned through the normal warranty route.
UK only – If the vehicle is located in the United Kingdom, please keep the handset aside for a period of one week in case it is required via a Parts Return Request. If no request has been made within this period, please return the handset through the normal warranty route.
Thanks!
Ok I'll try the hitting the button twice.. and thanks to whomever changed the title of my thread :)
Just had this problem with my 2013 sport. Replaced the battery, but it still showed the error until I pressed the lock and unlock buttons on the smart key twice. Worked like a charm. This site is a great resource
1 - 9 of 9 Posts
