So I was going to post this as a new thread but remembered I had already started this one. Hopefully this still gets the same visibility. Just copy pasting now with many more details than I had when I started this journey:
I have a 2008 Supercharged model that came with the 20 inch RRC502690MNH wheel. We picked up a set of 19 inch LR4 takeoffs that are from the 2010-2015 era and LR051523 is the current part number (replaces LR013925, LR028929). My 20 inch wheels have an offset of 58mm according to hubcaphaven. On the site it lists the offset of the LR4 rim as 53mm while the 19 inch wheels that come stock on the L322 are both listed as 57mm. Is there any kind of safety or wear issue when using the LR4 wheels? Aesthetically I prefer the older 19 inch RRC001270MNH that came during the BMW time to the one they came out with for 2006-2009 (RRC502640MNH). Would there be any issue using the older wheel as long as you have the correct wheel nuts for your model year?
The LR4 wheel does fit and I have driven on it with Atturo Trail Blade mud terrains, but they are currently off the vehicle. I know there was an odd sound I was getting that went away a bit when I swapped the bigger wheels back on but wanted to check in with the braintrust here to see if they had more info. I was also looking at getting the Compomotive 18 inch wheels but wasn't getting solid confirmation that they would clear the calipers on the Brembo brakes. I know for certain they fit the 2010+ HSE models with the larger rotors, 2006-2009 HSE models, and 2005-2009 Range Rover Sport Supercharged with the Brembo brakes. I believe the Brembo calipers on the 2006-2009 Supercharged are unique to that model. Johnson Rods said maybe, Compomotive themselves couldn't give me an answer one way or the other, and Vogue Xpeditions said they would fit. Photos below.
LR4 wheel:
72215b Land Rover LR4 Wheels Silver Painted rims LR028929
www.hubcaphaven.com
Stock 20s that come with the vehicle:
72197 Range Rover Wheels Silver Painted rims RRC502690MNH
www.hubcaphaven.com
2003-2005 19 inch:
72173 Range Rover Wheels Silver Painted rims RRC001270MNH
www.hubcaphaven.com
2006-2009 19 inch:
72198 Range Rover Wheels Silver Painted rims RRC502640MNH
www.hubcaphaven.com
Compomotive:
PRODUCT DESCRIPTION: The Compomotive PD1881. These 18″ wheels fit the Land Rover Discovery 3, 4, New Discovery, Range Rover L322 and Range Rover Sport (only models 2005 - 2009). Most 18″ wheels will not fit the Discovery 4 nor Range Rover Sport due to the bigger factory brake setup, this wheel...
www.voguexpeditions.com
