2013-2015 Range Rover Sport
I have a 2014 RRS SC 5.0/V8 Dynamic. I believe 20" wheel is doable with the Brembo's? 19" looked like an option prior to the 2014/L494 body change. Is there still a 19" rim that is compatible with 2014+ models?
Looking to have another set of wheels for offroading and winter with as much rubber as possible.
TIA
2016-2018 Range Rover Sport
You can use aftermarket rims with 255/55/20.
I do not think OEM 20 inch rims fit over the brakes.
Original RRS 20 inch five split-spoke ‘Style 12’ were (no cost?) option for 2014 . Brake diameter at the front is 380mm, over which these wheels will fit.
OEM rims with 255/55R20 (standard size in ZA).
You can't go any smaller than 20"
I was confused and wrong.
The parts department told me that only 21s fit over the brakes. I thought it was strange?
But now I think about it, they had a 21 snow set in stock and were pushing me to take them.
Sorry for the misinformation!
Thank you for the great responses. I'm considering one of these Redbourne 20" rims - for a more off-road look. Everything I have come across indicates they are compatible.
PCD compatibility is one thing, but double-check the load rating - RRS is a heavy vehicle and you need to make sure that the wheels are strong enough!
  • Like
Reactions: delray
