Topped off my oil last week as it was down a little bit; may have put a little too much in but nothing drastic. My wife noticed that the vehicle shakes while stopped. Very faint but if you put a piece of paper down it will vibrate (if that gives an idea what I'm talking about). It has not been shaking like this for ever but honestly I didn't notice it until she mentioned it. That said, she had not been in the vehicle for a week or so as we just had our son.
The idle is also under 1.
Anyone have any ideas?
Without knowing more, it is hard to say.
I'd say the most likely culprits are:
1. Vacuum leak of some sort
2. Dirty/Worn spark plugs
3. Ignition wiring
4. Motor/transmission mounts
5. Something amiss in the intake/fuel system
Most likely it isn't something major as long as you don't wait until more problems arise, however if you don't DIY, it could potentially be some expensive trial/error at the dealer depending on the skill/experience of the mechanic.
Huh. Well, could be the spark plugs as the RR have 65K on it, however, took a look & they are clean/fine. Am thinking it may have something to do with putting 87 in the gas tank rather than premium. Should not be something with the intake system though... sort of related; had my 2nd cat converter put in back in Feb.
