I know that this is probably a door latch from reading the forums, but I wanted to ask anyways before I shelled out $189.
My 2000 4.6 has the typically locking unlocking problem, but only the passenger, and rear doors. (I am LH drive). It's never the driver side, and if I open the door it is not alarmed. This I think has caused the battery to drain faster then normal.
The only thing I think could have something to do with it is I moved the strike plate on the frame to help the door close more tightly. Any chance if I moved this around I would get rid of the ghost?
Thanks, DM
Thanks, DM
Before you shell out anything, do the door latch tests in FAQs Sticky at top:
http://www.rangerovers.net/forum/7-range-rover-mark-ii-p38/131722-info-front-door-latch-tests.html
If the door latch wasn't properly engaged with the striker plate you'd get a door open warning (assuming latch switches were OK) so do the tests on both front doors first.
