1 - 1 of 1 Posts
Hey guys I have a fun one. My Range Rover always leaks the littlest bit of coolant out of the overflow hose. It's a very slow leak, I can drive the car for 100+ miles and only loose about a half a gallon (1.8 liters) of coolant but it's just plain annoying.
A while ago I had over heating issues and replaced the following:
- Radiator
- Water Pump
- Thermostat
- and Head Gaskets (after having the heads machined)
The car no longer over heats, the needle sits almost dead center (literally 1 needle width off center) but I have this leak so I replaced:
- the coolant cap
- the coolant tank
- the thermosat again, this time with a Atlantic British one
All that and still no luck, I'm out of things to replace. The fan seems find and it's clutch works. What would you try next?
1 - 1 of 1 Posts
