Hi all,
I must confess that I have not contributed to the Forum for ages, primarily because my high mileage ((350,000km) P38 4.6 HSE (1997) has been performing faultlessly for ages.
I have just returned from a boating trip towing my heavy yacht back from the Gippsland Lakes. The day was very hot. The engine cooling seems perfect. Very steep terrain.
I noted that although the engine starts well and runs smoothly without great oil consumption or smoking , it's power seems to be down. In fact on particularly steep hills it may be back by a gear and 20 km/hr. Fuel consumption, always heavy does not seem greatly worse, country driving without towing about 14.2lt/100 km, 21/100km heavy towing.
The reduction of power is more noticeable at lower revs. In deference to the cars high mileage I do not drive the car hard, keeping RPM below a max of 4000 even on the steepest hills. The reduction in power may have been occurring over some time but not noticeable as I was not towing.
The cars exhaust is burnt out which I will now replace. Filters etc are all clean. I have not compression tested it though it cranks smoothly.
Question!
What thoughts do readers have regarding the reduction in power, considering it's smooth and otherwise faultless running ?
Is it possible that it is suffering from cam wear (it is not mechanically noisy)?
Could the catalytic converter be collapsing?
I am considering removing the heads and inspecting and I am happy to have them reconditioned but I am loath to disturb an old motor that does not require it.
Can the sump be removed without removing the engine? I am happy to replace rings and bearings.
The problem is with the Rangey is that although I am supremely happy with it, is that it's very low monetary value means it would be easy to over capitalise it, not that I'm adverse to spending money on it.
Any thoughts or ideas greatly appreciated
regards
Alan
Question!
regards
Alan
