Hello guys ,I am trying not to look newbie :oops: ,I did a lot of research but ultimately I have to get back here ,
[attachment=0:3gdyowu9]35.JPG[/attachment:3gdyowu9]
I bought those chrome side vents to replace the standard ones ,however when I was looking up forums to find a safe way to remove the vents ,I came a cross this link http://rrsport.co.uk/forum/topic5448.ht ... =side+vent
I noticed that one of the vents has a protrusion( later on learned it is called Air intake unite ) and the ones I purchased basically r just flat?
My questions ,is it safe to install those chrome vents ,and forget about the air intake unit or this chrome vent can be attached to the air intake unit and I just need to put it back on ?
Do u agree on this tutorial of removing the side vent or you know a better/safer method .
Thanks a lot
You will not have a problem using those vents and any type of "stiff" plastic tool will work. I would line the bottom edge with tape to protect the paint in case you get carried away. ibis1 ;)
