I recently purchased a 2011 SC with 104K miles on the clock. The previous owner had a warranty contract from US warranty. During past two years under his ownership, he addressed some big ticket items like timing chain components, fuel pumps, control arms etc.
The previous owner offered to transfer the remainder of the warranty Aug/2021 or 33K miles to me for $2700
On one hand, he addressed all the big ticket items already. However, the car is also over 100K miles. The big question of course...Should I pay him for the remainder of the warranty? I am hoping that some of the long standing members, especially the ones with L322 10-12 can lend some of their wisdom to help me make this decision.
Below you will find an approximate service history and a copy of the US warranty contract the car is under. Thank you in advance
M
M
Date | Milage | Description | Type |
5/16/19 | 103732 | Oil/Filter Change | Maintenance |
5/16/19 | 103732 | HVAC Blower replaced | Repair |
3/25/19 | 102229 | Replace Front Air Suspension bags | Repair |
3/25/2019 | 102229 | Replace Both Lower/Upper control arms | Repair |
3/25/2019 | 102229 | Replace LF Axle seal | Repair |
3/25/2019 | 102229 | 4 Wheel alignment | |
6/8/2019 | 90261 | Timing Chain, Guides, Blades, Tensioners, Lower/Upper timing cover | Repair |
6/8/2019 | 90261 | Replace both high pressure fuel pumps | Repair |
6/8/2019 | 90261 | Replace Water pump, oil cooler seal and tube, throttle hose and thermostat | Repair |
4/27/2018 | 87539 | Oil/Filter Change | Maintenance |
09/19/2017 | 77905 | Replace Susp Compressor Assembly | Repair |
07/05/2017 | 75468 | Passanger Airbag recall | Maintenance |
04/03/2017 | 73787 | Replace DTML Pump | Repair |
08/17/2016 | 68905 | Rotate Tires and alignment | Maintenance |
01/19/2016 | 64102 | Front Brake hoses recall | Maintenance |
7/1/2015 | 57945 | Oil Change | Maintenance |
7/1/2015 | 57945 | 60K mile service | Maintenance |
12/02/2014 | 51241 | Battery Replaced | Maintenance |
12/2/2014 | 51241 | Updated Engine Control Module P039B | Repair |
06/12/2014 | 45193 | Oil Change | Maintenance |
06/12/2014 | 45193 | Align/recalibrate sunroof | Repair |
06/12/2014 | 45193 | 45K mile service, replace tires, alignment | Maintenance |
03/23/2013 | 31655 | CodeC110C-14 Front left wheel solenoid wire harness replaced | Repair |
