Hey welcome, what part of AK?
try checking the following:
look & listen for vac leaks, intake restrictions, or a cracked intake boot letting un-metered air into the mix.
Air & Fuel Filters
Clean & lube stepper motor on the back of the intake.
check engine coolant temp sensor.
Plugs wires cap & rotor
fuel pressure
voltage to fuel pump
check timing
Ignition module
without looking at it I'm totally just guessing..
& i'm no expert.
Download the Rave manual Here:
http://www.green-oval.com/joomla/index. ... &Itemid=29
& Before you buy a total POS, check out some of the other cheap rovers for sale locally.
http://anchorage.craigslist.org/cto/1570287046.html
http://anchorage.craigslist.org/cto/1600644609.html
http://anchorage.craigslist.org/cto/1596704343.html
Air & Fuel Filters
fuel pressure
check timing
Ignition module
& i'm no expert.
